Flat Charge
Flat Charge calculation rules create bill lines that levy service charges and fees that aren't based on how much the customer uses. For example a flat charge calculation rule may be used to apply a monthly service charge of $10 to a customer's bill.
  • Rule Name: Flat Charge
  • Base Package Calculation Rule Business Object: C1-FlatCharge
  • Apply Calculation Rule Algorithm Type / Algorithm: C1-FLAT-CHRG
  • Rule Parameters:
    • Calculation Details: Details regarding how the calculation rule performs its calculations:
      • Seasonal: See Common Parameters.
      • Value Type: Defines the type of value to use for the rule. For Flat Charge rules, this should be set to Charge.
      • Value Source: Specifies the source of the price used to calculate the charge. Depending on the source selected, this will be a Bill Factor, Value, or Algorithm.
  • Example: This calculation rule levies a customer charge.
    Calculation Group: Customer Charge
    Calculation Rule: CSTCHG
    Sequence: 20
    Description: Customer Charge
    Description On Bill: Customer Charge
    Print: Yes
    Print if Zero: No
    Rounding Type: Nearest
    Precision: 0.01
    FCPO: No
    Override Proration: No
    • Seasonal: No
    • Value Type: Charge
    • Value Source: Value
    • Value: 5
      GL Distribution:
    • Distribution Source Code: Specific Distribution Code
    • Distribution Code: Revenue - Energy
      Cross Reference:
      • Member Category (Category Type / Value): Subject to tax / City taxable
