Script Options
We use the term "script" to define processing rules that your implementation sets up to control both front-end and back-end processing:
  • Rules that control front-end processing are defined using Business Process Assistant (BPA) scripts. For example, your implementation could set up a BPA script to guide a user through your organization's payment cancellation process.
  • Rules that control back-end processing are defined using Server-based scripts. For example, your implementation could set up a server-based script to control the processing that executes whenever a given type of adjustment is canceled.
The topics in this section describe how to configure your scripts.
