Setting Up Field Activity Remarks
You may link remarks to a field activity using remark codes. To define field activity remark codes, open
Description of Page
Enter a unique Field Activity Remark and a Description for every field activity remark.
Turn on Eligible for Processing if field activities marked with a given remark code should cause one or more algorithm to execute.
The grid contains Algorithms associated with the field activity remark. You must define the following for each algorithm:
- Specify the System Event with which the algorithm is associated (see the table that follows for a description of all possible events).
- Specify the Sequence Number and Algorithm for each system event. You can set the Sequence Number to 10 unless you have a System Event that has multiple Algorithms. In this case, you need to tell the system the Sequence in which they should execute.
The following table describes each System Event.
System Event |
Optional / Required |
Description |
Field Activity Remark Activation |
Optional |
These algorithms are executed when there are pending FA remarks linked to a field activity and the FACT (Field activity remark activation) background process runs. Refer to Field Activity - Characteristics/Remarks for more information. |
