Setting Up Service Codes
Service Codes are used to create the appropriate work record from the service call
Refer to Asset Management System Integration for more information.
To set up service codes, open Admin > Field Work > Service Code — CCB > Search.
This is a standard All-In-One Portal.
The information captured on the service code depends on the business objects that your implementation supports. Refer to the embedded help text for more information.
