Override Maps
Assume that you have contracts with customers where the standard classic TOU map is overridden on certain days, for example, for interruptions. The customer is informed of these interruptions ahead of time so that they can plan their usage accordingly. Let's assume that the price for usage during these interruption days is more than the standard TOU Price.
Let's assume that the contract identifies the following time period definitions
Time Period Name
TOU Code
Description
Price
On Peak, Summer
ONSUM
The TOU for the standard map for May through September, inclusive for the times 08:00 through 16:59
$0.0488
Off Peak, Summer
OFFSUM
The TOU for the standard map for May through September, inclusive for the times 00:00 through 07:59 and 17:00 through 23:59
$0.0391
On Peak, Winter
ONWIN
The TOU for the standard map for October through April, inclusive for the times 08:00 through 16:59
$0.0421
Off Peak, Winter
OFFWIN
The TOU for the standard map for October through April, inclusive for the times 00:00 through 07:59 and 17:00 through 23:59
$0.0347
Interruption, On Peak
ONOVR
The TOU for the interruption period. This is not season dependant and covers the times 07:00 through 17:59.
$0.0504
Interruption, Off Peak
OFFOVR
The TOU for the interruption period. This is not season dependant and covers the times 00:00 through 06:59 and 18:00 through 23:59.
$0.0418
As you can see, the contract is set up to designate that on these special interruption days, the definition of on peak changes to include two extra hours, and the price per TOU is higher than on the standard days.
