Override Maps - Map Relationship Type and Map Type
You need to define a map relationship type and map type for classic TOU map.
For this example, create a generic Map Relationship Type of MEASUSAGE.
Create a map type that is used for customers using the contract defined above with possible overrides. Call it INTRPT30. Define the other attributes as follows:
  • TOU Group is INTERRUPT
  • Minutes Per Interval is 30 minutes
  • Algorithm Type is Creation with an appropriate creation algorithm. A new algorithm type needs to be created by the implementers. Refer to Override Maps - TOU Data Creation Algorithm for information about this algorithm.
Once you have created the map type, go back to the map relationship type and update its valid map types list to include the new map type.
