Create Conversion Data Files
In this step you create the set of data conversion files that were identified for the conversion process. You can choose to generate data files for each staging table or create a smaller set for each converted Maintenance Object.
The data conversion files typically do not include all the data to begin with but start small and grow with every iteration of the conversion process until they reach their maximum size at the end.
Note: When performing data conversion in the cloud, customers
don’t have access to the database staging tables. Data scrubbing and
transformation activities has to take place before the data files
are generated (in each conversion iteration) so the result of these
activities is reflected on the data files that are moved to the cloud
to be loaded into the staging tables.
