Process Converted Data in Cloud Application
When the data intended for conversion (for a conversion iteration) is loaded into the appropriate conversion staging tables, the OUAF application in the cloud can process that data according to the product’s data model, technical and business rules.
Refer to the OUAF product specific documentation for further guidelines and information on the specific processes and guidelines related to data conversion.
- Validation of the data in the conversion staging tables.
- Generation of the system assigned keys for the converted entities.
- Migration of the converted data from the staging tables into the actual system tables.
When the processing of the converted data in this iteration is completed, information from the system is used to identity changes necessary to source data, the extraction process or other activities involved in producing the data to be converted.
The process can then start over by loading a new set of data into data conversion files, load them to the staging tables in the cloud and process them once more to get more feedback.
