Process Conversion Data Files
After uploading the files to the cloud, you should run a set of batch processes that will process the data files using Oracle SQL Loader and insert the data to the product conversion staging tables.
The staging table load process also produces output files that provide feedback on the load process.
You can download these output files for review using the same sFTP
client you used to upload the data file.
Note: The process that imports
the data in the files to the staging tables, using Oracle SQL Loader,
is using the artifacts that were generated in the “Prepare for Conversion”
step.
For more details refer to Understanding Load Data Process .
