Extension Points
You can configure the experiences using the Oracle Visual Builder Studio application. Oracle Visual Builder Studio is an application development platform that helps you to develop an application extension and manage the entire development life cycle, from creation to publication.
Here are the extension points available:
                     Dynamic Forms and Tables: Enables extensions to add, remove, reorder, or change the rendering of fields.
                     Dynamic Containers: Enables extensions to insert content and to add, remove, or reorder base application content.
                     Constants, Variables, and Types: Extensions can override base application constants or read and write to variables made available by the base application. User-defined types can also be made available for use by extensions.
                     Events: Enables extensions to trigger base application behaviors or to respond to events initiated by the base application.
                     App UIs (New Flows): Extensions can define new app UIs in which they can create new UI flows that are either linked from or embedded within existing pages.
For additional information about configuring and extending Oracle applications, see Configuring and Extending Applications in the Applications Common library on Oracle Help Center.
Parent topic: Implementation Overview
