Setup Tasks
This section discusses the two different types of setup tasks that you must complete to use the Customer Experience for Utilities solutions. First, you complete the provisioning tasks, which includes provisioning each of the products included in the solution, and completing the steps that connect those systems so that data can flow between them. Once you have completed the provision steps, you complete the user and application setup steps, which includes creating and managing users and roles, and setting up the features you will use in each of the applications.
Provisioning Tasks
The first part of the setup process is to provision your systems, and connect them so that users can access each system, and data is easily shared between them.
This diagram provides an example of what your implementation looks like before completing the provisioning tasks:
Figure 2-4 Pre-Provisioning Example
This diagram provides an example of what your implementation looks like after completing the provisioning tasks:
Figure 2-5 Post-Provisioning Example
These tables list the provisioning tasks that you must complete, in order, to implement Customer Experience for Utilities solutions.
| Setup Task | Reference |
Complete initial registration and administrative tasks, which include:
Complete utility configurations using REST APIs, which includes:
See Configure Utility Details. |
| Configure the initial data synchronization (for implementations with existing CIS data only) and ongoing data synchronization process. | See Configure Data Synchronization. |
Configure Single Sign On (SSO) which includes:
See Configure Single Sign On. |
Configure user synchronization between source systems, which includes:
See Configure User Synchronization. |
Perform the connectivity test. Once you have completed this step, the remaining setup tasks can be done in order. |
See Perform a Connectivity Test. |
User and Application Setup Tasks
After you have completed the provisioning setup, use the table below to identify the steps you must complete to set up users and enable features in your applications.
Manage users and roles, which includes:
See Manage Users and Roles. |
Configure these items in your Oracle Utilities customer information system:
See Configure Your Oracle Utilities System. |
Configure Oracle Fusion applications, which includes setting up:
See Configure Fusion Applications. |
Set up the Redwood Sales Interface for CX for Utilities Sales, which includes:
See Configure the Redwood Sales Interface. |
| When you have completed all of the setup steps, test your setup by completing standard end user tasks. | See Test Your Setup. |
Parent topic: Implementation Overview
