2 Implementation Overview
Before you can use any of the Oracle Customer Experience for Utilities solutions, you should have a complete understanding of how the different Oracle systems are integrated, the technical requirements that must be met, and the implementation steps you must complete to successfully implement the solution.
This chapter provides an overview of the solution architecture, lists technical requirements, discusses possible extension points that are available, and provides a list of the tasks you need to complete for your implementation.
In this chapter:
