Register Your Oracle Utilities Environment and Fusion Applications
After your Oracle applications are provisioned, you must register your Oracle Utilities customer information system environment with CX Industry Framework. The steps in this process are completed with assistance from the Oracle delivery team. You will work with them to enter client-specific information during the registration process.
When you are ready to complete this task:
Create an administrative user in CX Industry Framework.
Complete the registration steps outlined in My Oracle Support Document 2913192. Contact your Fusion Application Support team if you need assistance. This task should be completed every time you upgrade to a new release. See Upgrade Considerations.
Register your CX Industry Framework system account in Fusion Applications. For details, see the System Registration Tasks section in Fusion System Registration Tasks.
Create an Administrative User in CX Industry Framework
You create this user to administer the utility configurations.
1. Log in to your CX Industry Framework identity domain as an administrator.
2. Create and activate a new user account using the following information:
Select Oracle Cloud Services from the navigation panel and locate the application corresponding to the CX Industry Framework instance. The name starts with CXIF, and the description likely reads "CXIF IDCS Application". It was created during the CX Industry Framework provisioning process.
Select the application and then, under Resources, select Application Roles.
Assign the user to the following roles, which are required for Utility Configuration API access:
CXIF_Configuration_API_Registration_Read
CXIF_Configuration_API_Registration_Write
CXIF_Configuration_Endpoint_Read
CXIF_Configuration_Endpoint_Write
CXIF_Configuration_Routing_Read
Parent topic: Provision Your Oracle Cloud Applications
