Maintaining Program Subscriptions
The Program Subscription portal is used to display and maintain program subscriptions.
Refer to About Program Subscriptions for more information.
You can access the portal from Menu, select Digital Asset Management, then select Program Subscription. You are brought to a query portal with options for searching for a specific record. Once a program subscription has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Program Subscription: This zone displays general information about the program subscription, such as the customer, status, and event calculation groups.
Event Participation List: This zone lists the events in which program subscription was a participant.
Attribute Values: This zone lists attribute values whose characteristic type have Program Subscription as characteristic entities and are defined as valid Program Subscription characteristic types on the Program Subscription Type.
