Configuring Current Activities Zone
Asset Zone
The Current Activities zone displays the number of current (non-final) activities for the asset, along with up to five of these activities ordered by Total Risk Priority (highest first) and Required By or Activitation Date (oldest first).
Example of an Current Activities Zone.
Insight Group
An insight group is required to display the badge and activity list.
Create a new insight group for the Asset 360 Current Activities:
  • Insight Class: Asset 360 Current Activities
  • Valid Visual Structures:
    • Badge Insight
    • List Insight
Example of an Insight Group
Next, add your insight types by clicking Edit in the Related Insight Types zone:
Table 1. Insight Type Example
Sequence Insight Type
10 Asset 360 Current Activities Badge
20 sset 360 Current Activities List
Note: Refer to each insight type below for additional setup requirements.
Current Activities Badge Insight Type
Example of Current Activities Insight Type
If the number of current activities for the asset is five or less, the information is displayed using the Default Insight Color Option. If there are more activities than displayed in the zone, it uses the Override Visual Settings.
Current Activities List Insight
The current activities list displays up to five of the asset’s current activities, ordered by Total Risk Priority (highest first), Required By Date (oldest first), and Activation Date (oldest first).
Example of Current Activities List Insight Type
By default, if the Required By Date has passed, the activity information is displayed using the Override Visual Setting - Severity Value 30. If the date has not passed, the Default Insight Option is used.
Lastly, follow the steps for Bucket Configuration and Algorithm Parameters to display the Override Visual Settings based on Total Risk Priority.
Create a new Total Risk Priority bucket configuration using the Asset Bucket Configuration BO. Refer to the screenshot below for suggested Bucket Value Ranges:
Example of Bucket Configuration Values
Once the Total Risk Priority bucket configuration is set up, edit the Asset 360 Current Activities List (W1CURACTLIST) algorithm to add the new algorithm parameter values:
  • Bucket Configuration: The bucket configuration you created above
  • Severity Number 1-10: The Override Severity Value for it's corresponding Bucket Sequence Number. Leave blank to use the default visual setting.
  • Bucket Sequence Number 1-10: Sequence numbers defined in the Bucket Value Ranges
For example, to display an orange badge (override value = 20) for a Medium (bucket value sequence number = 20) Total Risk Priority:
  • Severity Number: 20
  • Bucket Sequence Number: 20
Example of Bucket Severity Values
