Maintaining M&V Subscriptions
You use the M&V Subscription portal to display and maintain M&V subscriptions.
Refer to About M&V Subscriptionsfor more information.
You can access the portal from Menu, select Digital Asset Management, then select M&V Subscription. You are brought to a query portal with options for searching for a specific record. Once an M&V subscription has been selected, you are brought to the maintenance portal to view and maintain the selected record.
M&V Subscription: This zone displays general information about the M&V subscription, such as the customer, status, and event calculation groups.
