Maintaining  M&V Transactions
You use the M&V Settlement portal to display and maintain M&V transactions.
Refer to About  M&V Transactions for more information.
You can access the portal from Menu, select Digital Asset Management, then select M&V Transaction. You are brought to a query portal with options for searching for a specific record. Once an M&V transaction has been selected, you are brought to the maintenance portal to view and maintain the selected record.
  • M&V Transaction: This zone displays the selected M&V transaction.
  • SQ Details: This zone displays service quantity details for the M&V transaction.
  • Baseline Measurements: This zone displays interval data used in calculating the M&V transaction (if applicable).
