Creating Web Maps Using ArcGIS Portal
Create a web map using ArcGIS Online or ArcGIS portal. For instructions to create a web map using the ArcGIS portal, refer to ESRI ArcGIS information.
The web map includes layers from the published map/feature services (Utility specific network map service, Work Locations map service, and an optional Map Notes feature service) in ArcGIS Server. Make sure that the web map is shared to the intended users.
Connecting ArcGIS Portal with Enterprise LDAP
Note: This step is optional.
The integration of ArcGIS portal with Enterprise LDAP ensures that the users in an organization should be created/managed on the portal page and the authentication is done using LDAP.
Configure the identity store accordingly and then import the enterprise users into the ArcGIS portal.
For more information about configuring the identity store and importing the enterprise users, refer to ESRI ArcGIS information.
