Maintaining Event and Customer Settlement Transactions
The Event Settlement Transaction portal is used to display and maintain event and customer settlement transactions.
Refer to About Event Settlement Transactions and About Customer Settlement Transactions for more information.
You can access the portal from Menu, select Digital Asset Management, then select Event Settlement. You are brought to a query portal with options for searching for a specific record. Once a settlement transaction has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Event Settlement: This zone displays the selected settlement transaction.
Event Settlements: This zone displays a list the event settlements totalized in the selected customer settlement transaction.
