Maintaining Program Transactions
The Program Transaction portal is used to display and maintain program transactions.
Refer to About Program Transactions for more information.
You can access the portal from Menu, select Digital Asset Management, then select Program Transactions. You are brought to a query portal with options for searching for a specific record. Once a program transaction has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Program Transaction: This zone displays the selected program transaction.
