Maintaining Program Events
The Program Event portal is used to display and maintain program events.
Refer to About Program Events for more information.
You can access the portal from the Program context menu when viewing either a Program Subscription or Program. Users select Go To Program Event from either of the context menus and are are brought to a query portal with options for searching for a specific record. Once a program event has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Program Event: This zone displays general information about the program event, such as the program, status, program category, the start and end date/time of the event, and an external event identifier (if applicable).
