Defining Program Calculation Groups
You use the Program Calculation Group portal to display and maintain program calculation groups.
Refer to Understanding Program Calculation Groups for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Calculation Group. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Program Calculation Group: This zone displays basic information about program calculation group.
Program Calculation Rules List: This zone lists the program calculation rules belonging to the group.
