Defining Program Types
You use the Program Type portal to display and maintain a program  types.
Refer to Understanding Program Types for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Type.
The following zones may appear as part of the portal's Main tab page:
  • Program Type List: This zone lists all program type records. Broadcast a record to display the details of the selected record.
  • Program Type: This zone displays the selected program type.
