Green Button
The Green Button allows customers to export their billing data into CSV or XML format. It is typically located beneath the Data Browser. When a customer clicks the Green Button link, a Download my data section displays and allows the customer to choose between downloading their data in CSV or XML format.
Green Button Example
The images below show examples of the Green Button feature's behavior. Typically the Green Button is displayed under the Data Browser.
Screenshot of the Data Browser with the Green Button link.
When a customer clicks the Green Button link, a Download my data section displays and allows the customer to choose from different options. The options displayed vary depending on whether the customer has billing data or AMI data. The example below displays options for customers who have AMI data.
Screenshot of the Green Button Download My Data section, which alllows customers to download billing data. Options avialable for all bill totals or specific bill periods. Format options include CSV and XML.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Enable Five-Minute Data Intervals
You can enable rows to display five-minute usage data intervals in the downloaded energy use file. This is supported for customers with five-minute AMI data.
Default: Disabled. (Five-minute intervals are summed up to 15-minute intervals.)
Optional
  • Use the default option.
  • Enable rows for five-minute intervals to display.
User Experience Variations
The user experience of the feature may vary for customers and utilities depending upon their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see Green Button in the Digital Self Service Energy Management Cloud Services Overview Guide and go to the User Experience Variations section.
