Review Algorithm Spot Definition
The algorithm spot definition identifies the purpose of the algorithm spot and the required methods per implementation. It may also help to look at existing implementations of the relevant algorithm spot.
The relevant algorithm spot in this example is
AdhocCharacteristicValueValidationAlgorithmSpot in
com.splwg.base.domain.common.characteristicType.
