The BatchJob Annotation
Each BatchJob class must declare a BatchJob annotation that
specifies important attributes of the job. An example is shown below:
@BatchJob (rerunnable = false,
multiThreaded = true,
modules={todo},
softParameters = { @BatchJobSoftParameter
(name=OUTPUT-DIR, type=string) },
toDoCreation = @ToDoCreation (drillKeyEntity = user,
sortKeys = {lastName, firstName},
messageParameters = {firstName, lastName}
The annotation declares if the job can be rerun, supports more than one thread of operation,
the modules that the job belongs to, its nonstandard runtime parameters and the details
of how ToDo entries should be created in the case of errors. When not
specified in the annotation, default values will be used.
