Creating the Implementation Class
There is very little that needs to be done by application developers to create a basic business entity. In addition to the setup of the CI_MD_* tables describing the entity and its constraints only an implementation class (or "Impl" for short) needs to be added. In this case a developer added Person_Impl. The following is a simple example of an "Impl" class for the Person entity.
* @BusinessEntity
* (tableName = CI_PER,
* oneToManyCollections = { @Child( collectionName = names,
* childTableName = CI_PER_NAME,
* orderByColumnNames = { SEQ_NUM } )
public class Person_Impl
extends Person_Gen {
* @return the UI Display "info" for this person
public String getInfo() {
return "PrimaryName: " + getPrimaryName().getInfo();
Important parts of the implementation class are described below:
- The implementation class name must end with the suffix "_Impl". For example, if the entity has a name of "person" then the implementation class name of "some.package.Person_Impl". It also means that the generated business interface will have a name of "some.package.Person".
A Class Annotation which declares:
- What table this entity represents
- What the owned-child tables are and what they should be called
- Other information. Please see the BusinessEntityAnnotation class for more details.
The class extends an abstract superclass having the suffix of "_Gen". Continuing the example of an entity named "person", the implementation class would extend a not-yet-created abstract superclass named "some.package.Person_Gen". This superclass is created by the artifact generator based on metadata about the table and contains:
- Getter methods for properties including parent objects and collections
- The getDTO() and setDTO(...) methods that allow for properties to be changed
- Access to standard framework methods like createQuery(...)
- Business methods. Any hand coded public methods are automatically exported onto the generated business interface (e.g. "some.package.Person"). Client code can then access the added business method as follows:
Person aPerson = some logic retrieving a person instance
String thePersonsInfo = aPerson.getInfo();
- Constants. Any hand coded public static final variables are automatically exported onto the generated business interface. This will be useful for constants related to the entity.
- Having created a new entity, it is likely that validation rules and other behaviors should be added to it. Please see Adding Change Handlers for more information.
