External System
You must create an External System for each external system to which Oracle Utilities Smart Grid Gateway will send messages. Each external system defines a set of outbound message types that will be sent to that system. Each external system outbound message type also specifies the following:
  • The processing method used to send the message (Batch or Real-time)
  • The corresponding message senders
  • Batch Control (if Processing Method is set to Batch)
  • Message XSL, W3C Schema, and Response XSL (as applicable)
