Trouble Info Tab Menus and Toolbar Icons
The Trouble Info tab changes dynamically based on the view. The following tables describe the menus and toolbar actions available in the Trouble Info views.
File Menu
Menu Option
Description
View
Toolbar Icon
Callers
Changes the Trouble Info tab to the Using the Trouble Info Callers View.
All
Customers
Changes the Trouble Info tab to the Using the Trouble Info Customers View.
All
Supply Points
Changes the Trouble Info tab to the Using the Trouble Info Supply Points View.
All
AMI Customers
Changes the Trouble Info tab to the Using the Trouble Info AMI Customers View.
All
Export Table...
Opens a dialog box to allow you to save the current table view data to a comma separated value (csv) file.
All
Print
Opens the Print Preview dialog box, allowing you to print the current contents of the current view.
All
Sort Menu
Menu Option
Description
View
Sort Dialog...
Opens the Sort Dialog, which allows you to choose the sort columns and type (that is, ascending or descending).
All
Default
Sorts the table according to the default settings for the view.
All
Actions Menu
Menu Option
Description
Views
Icon
Refresh
Refreshes the data in the current view.
All, except AMI Customers
Call Info...
Opens the Call Info window for the selected call. See “Viewing Call Info”.
Callers
Ungroup
Opens the Ungroup dialog box, allowing you to ungroup the selected calls from the event.
Callers
Unassociate
Opens the Unassociate dialog box, allowing you to unassociate the selected calls from this device and (optionally) associate them with a new device. See Unassociating a Call from a Device for more information.
Callers
Transfer Call
Opens the Transfer Call dialog box, allowing you to transfer the selected call(s) to a different event. See “Transferring a Call to a Different Event” for more information.
Callers
Move Customers...
Opens the Move Customers dialog box, allowing you to move selected customers to a new device. See “Moving Customers to a Different Device” for more information.
Callers, Customers
Show DER Units...
Opens the Customer DER Units dialog box, allowing the user to view relevant information for each customer DER unit.
Note: This option will only be enabled if the DER count column is equal or greater than one.
Customers
Edit Clues...
Opens the Edit Clues dialog box for the selected call. See Editing Call Clues for details.
Callers
View
Targets the Viewer on the Supply Point for the selected call.
Supply Points
Remove
Removes the selected device from the event.
Supply Points
Update Event
Updates the event by saving changes, such as removing a device from an event.
Supply Points
AMI Confirm
Requests meter pings from AMI system for the selected customers, if applicable. See “Creating AMI Requests” for details.
AMI Customers
AMI Load Side
Requests load side connection information from the AMI system for the selected customer.
AMI Customers
AMI Voltage
Requests a voltage reading from the AMI system for the selected customers.
AMI Customers
AMI Power History...
Opens the AMI Power History dialog box for the selected customer.
Note: If no AMI Power History data exists, a ‘No AMI Meter Power History' dialog box will be displayed.
AMI Customers
AMI Load Side History...
Opens the AMI Load Side History dialog
box for the selected customer. The table
displays the following:
• The date the load side connection information was received.
• The meter load side connection status.
Note: If no AMI Load Side History data exists, a ‘No AMI Meter Load Side History' dialog box will be displayed.
AMI Customers
AMI Voltage History...
Opens the AMI Voltage History dialog box for the selected customer. The table displays the following:
• The date the voltage data was received.
• The voltage value. For multiphase meters, this column may contain multiple voltage values.
Note: If no AMI Voltage History data exists, a ‘No AMI Meter Voltage History' dialog box will be displayed.
AMI Customers
Disable AMI
Disables AMI functionality for the selected meters. This option is only available when Oracle Utilities Network Management System is integrated with Oracle Utilities Smart Grid Gateway.
AMI Customers
Enable AMI
Enables AMI functionality for the selected meters. This option is only available when Oracle Utilities Network Management System is integrated with Oracle Utilities Smart Grid Gateway.
AMI Customers
