Understanding Table Components
The following image shows an illustrated screen capture of a table showing call outs for the components.
2. Disable filtering button (
) temporarily disables (removes) currently applied filters; clicking the button again restores the filters.
3. The applied filter name (for example, Default).
4. Filter breadcrumbs show the number of rows being displayed (based on filter criteria) and the quick filtering selections; see
“Understanding Quick Filters”.
8. The header row check box allows you to select all of the table rows.
9. The column sort arrow icon shows the current sort direction for that column; clicking it will sort the table by that column. See
“Understanding Table Sorting” for details.
