Get Directions or Access Other Map Views
The Diamond shape with arrow icon that launches a map application. Navigate menu allows you to select from options based on the object selected.
• Directions to Location opens a navigation site (in a new browser tab) to get directions to the object's location.
• Cycle Available Geographic and Internal Map Views cycles through different views of the device (schematics, geographic, and so forth).
• View Full Extent zooms out to show the device in relation to its network.
• Diamond shape with arrow icon that launches a map application. View in Geographic Map changes the Map to the geographic view.
• Diamond shape with arrow icon that launches a map application. View Schematic Map changes the Map to the schematic view.
• Diamond shape with arrow icon that launches a map application. View Single-Feeder Map changes the Map to show the feeder one line view.
Note: When using Flex Operations on a touchscreen, tap on a device to display a popup menu which enables you to:
• Display the selection panel
• View the device’s tooltip
• Display the device’s right-click menu
Understanding Crew Management Features in the Map
For a selected event or crew, the right‑click context menus provide the available options for managing the crews. For a selected event, options will only be available to manage crews associated with that event. Similarly for a selected crew, options will only be available to manage the crew on events that it is already associated with.
Setting Outages as Stable or Not Stable
Predicted outages can be marked as stable or not using these menu options on the event context menu. For a detailed description of the event stable functionality, see Working with Stable Predictions.
Repredicting Upstream / Downstream
Options to repredict the location of an event are available when applicable to the currently selected event. For a more detailed description of these options, see Repredicting Upstream/Downstream.
Viewing Downstream/Connected Customers
Click the Customer List... button to view a list of customers downstream of the selected device. To view additional customer-related information, right‑click and select one of the Customer options:
• Customer Call History...: Opens the Customer Information Drawer with the Call History tab in focus. See Viewing Customer Call History for more information.
• Customer Event History...: Opens the Customer Information Drawer with the Event History tab in focus. See Viewing Customer Event History for more information.
Note: A separate tab in the Customer Information Drawer displays Customer Details. See Viewing Customer Details for details.
Creating a New Event on a Device or Conductor
You can create a new event on a device or conductor.
1. For the selected object, select Create Event from the Event menu. The New Event dialog box will open.
2. Enter the new event information, then click OK.
See Creating an Event for more information.
Working with Notes
You can annotate, add, edit, and delete notes on the Map.
Adding a Note
1. With a device or conductor selected, select Add Note from the Selection Panel’s Tag/Note menu.
2. Enter the text and then click OK.
Editing a Note
1. In the Map, select the Note symbol, then from the Selection Panel, select Edit from the Tag/Note menu.
2. Edit the text, then click OK.
Deleting a Note
In the Map, select the Note symbol, then from the Selection Panel, select Remove from the Tag/Note menu.
Working with Tags
You can annotate add, edit, and remove device tags on the Map.
For more information about tagging devices, see Tagging Assets.
To add a tag:
1. In the Map, click to select a device or conductor, then from the Selection Panel select Add Tag from the Tag/Note menu.
2. Choose the tag type, if prompted, enter tag text, if applicable, and then click Instruct or Complete. The tag is added.
Editing a Tag
1. In the Map, select the tag symbol, then from the Selection Panel Tag panel, select Edit Condition from the Tag/Note menu.
Removing a Tag
In the Map, click to select the tag symbol, then from the Selection Panel Tag panel, select Remove Condition from the Tag/Note menu.
Operating Devices
The Operate Device dialog box is displayed when instructing or completing device operations; it allows you to verify important information before instructing or completing the device operation. It can be displayed from the Map or from a switching sheet.
As illustrated in the screen capture above, the Operate Device dialog box has the following fields and buttons.
1. The Device to be operated.
2. The Feeder for the device to be operated.
3. The Operation Time recorded. Default to the current time, but can be backdated if required, to allow for more accurate recording of time off / time restored.
4. The Record Into Sheet field allows you to choose where the device operation will be recorded. If you are recording into a switch sheet, you can still choose to record the operation into the Miscellaneous Log, if required.
5. The Comment field allows you to add a comment to the device operation. This will be seen in the Comment field in the switching step for the device operation in the switching sheet or Miscellaneous Log.
6. The Phases table allows you to select the phase(s) to be operated. All available phases are selected by default, but can be deselected by clicking the check‑boxes. Clicking anywhere else on a phase row selects that row and deselects other rows.
7. The Look Ahead Messages section displays safety or electrical information messages. For example, warns you that you are going to make or break a loop, or energize a grounded section. These messages must be acknowledged/checked before the command buttons (for example, Instruct Close [Device]) become enabled.
8. The tabbed Look Ahead section provides information relevant to the impending device operation. Some information can be configured such that it must be viewed before operating the device. In cases like this, the tab with the information will oscillate until selected; once the tab has been selected and the page viewed, the command buttons become enabled.
9. Command buttons allow you to instruct or complete the device operation. These buttons will only become enabled once any electrical look ahead messages and conditions have been acknowledged.
You can operate devices as described below.
1. From the Map, select the device, then from the Selection Panel, select Open or Close, as applicable, from the Operate menu.
Note: The Operate Device dialog box will be displayed when executing switching sheet steps.
2. In the Operate Device dialog box, enter information as desired in the top panel. Things you may edit include the phases to be operated, where to record the action to (Miscellaneous Log or a switching sheet), and comments.
3. In the lower part of the Operate Device dialog box, view Look Ahead information. If the action results in conditions that need to be acknowledged, the Conditions tab will jiggle. Select the Conditions tab and view the results of the operation.
Note: For more information see Understanding the Look Ahead Dialog Box.
4. Once you have reviewed the information, click the Open or Close button, as applicable, to complete the operation.
In the Map, the device and network update to reflect the change in state.
Adding Damage Reports
1. In the Map, click to select a device or conductor, then from the Selection Panel, select Add Damage Report... from the Damage menu.
2. The new Damage Assessment is displayed in a tab in the Workspace.
Record Patrolling Updates
You can add and update patrolling conditions.
Adding a Patrolling Condition
1. In the Map, click to select a device or conductor.
2. From the Selection Panel, select Patrol Status, and then select the type of patrol condition to add:
• Add Patrolling Condition: Adds the condition in a Patrolling state.
• Add Device Patrolled: Adds the patrolling condition of Device OK.
• Network Patrolled: Adds the patrolling condition to All OK. Highlights all network downstream of the selected device in a patrolled color.
Updating the Status of a Patrolling Condition
1. In the Map, select the patrolling symbol.
2. From the Selection Panel Patrolling panel, select Edit Condition from the Tag/Note menu.
3. In the Patrolling Condition Details dialog box, change the condition status and add a description in the Text field, then click OK.
Removing a Patrolling Condition
1. In the Map, click to select a patrolling symbol.
2. From the Selection Panel Patrolling panel, select Remove Condition from the Tag/Note menu.
Feeder Highlights
You can highlight an entire feeder by hiding/subduing the other feeders.
For a selected device or conductor, click Feeder Highlights () then click Highlight Feeder. Other feeders will be displayed less prominently, but still be selectable (so you can highlight additional feeders).
To remove or clear feeder highlighting, click to select the feeder then choose Unhighlight or Clear Highlighting. You can also clear highlighting from the Highlighting indicator displayed in the top-right of the Map.
Customer List Options
The Customer List provides two options to view additional information about a selected customer.
• Customer Call History... (see Viewing Customer Call History for details).
• Customer Event History... (see Viewing Customer Event History).
Examining Network Devices, Assets, and Symbols
To find out more about an asset or symbol, select it and then click the Attributes button from the Selection Panel.
Using the Trace Feature
The Trace tab enables you to perform traces:
1. Click to select a network asset like a device or conductor.
2. In the Trace To box, select the trace stop class.
3. Choose the Direction to trace.
4. Choose the Phase(s) to trace.
5. Click to perform the trace.
After a trace has been performed you can perform the following actions:
• Clear () the trace as displayed on the Map
• Refresh () the trace
• Target () the trace, to the Extent of the trace, or on the Start Point
• View ()the Trace Results. Trace results are displayed in a panel, and for each result you can right-click to position on the object, or fetch calculated values.
A list of recent traces is displayed, and actions can be performed on each trace in the list. See Executing Traces for more information on trace options.
Selecting and Interacting with Multiple Map Objects
There are three tools available for selecting multiple objects on the map, which can be accessed from the tool selector drop down on the Map toolbar (Toolbar icon):
1. Box Selection: When in this mode, you can define a rectangle which will select all objects that overlap with that rectangle. You can define the rectangle by clicking and holding the left mouse button then dragging the mouse, or by clicking or tapping once to define one corner, then clicking or tapping again to define the other, which can be easier to accomplish on a touch device.
Note: This mode can also be accessed by holding shift and then clicking and dragging with the left mouse button. This will suppress the standard panning behavior and perform a box select instead.
2. Circle Selection: When in this mode, you can define a circle which will select all objects that overlap with that circle, by clicking and holding the left mouse button in th center of the circle, then dragging out to increase the radius of the circle.
3. Polygon Selection: When in this mode you can define a polygon which will select all objects that overlap with that polygon. To define the polygon click once to define the start point, then add more points by repeated clicks of the mouse. To complete the definition of the polygon either double click to place a final point and close the polygon, or click the starting point of the polygon again. The start point has an empty circle around it which will show filled when hovered with the mouse, to indicate it will be activated when clicked and close the polygon.
Note that in all of the above multi select modes the resulting selection is updated in real‑time as the selection area is being defined.
In addition to the above tools individual items can be toggled in/out of the selection by holding the Ctrl key while clicking with the left mouse button.
Selection Results Panel
Once a multi-select has been completed the Selection Results panel will be shown to allow the user to explore the objects that were selected.
When an item in the list is clicked it will be selected, the map will move to zoom and center on the object, and the selection panel shown just as if it had been clicked in the map.
When an item in the list is double clicked all of the above will happen and the Selection Results panel will close.
If any item in the map is right clicked then the same menu will be shown as if you right clicked the object on the map, with the addition of a "View on Map and Close Panel" action indicating the default action which will occur on a double click (described above).
After selecting items in the list, if you wish to return to a view with all of the items in the list visible and selected in the map, press the "Position, zoom and select so that the full list is visible and selected" button on the title bar of the Selection Results panel.
Map Selection Filtering
When performing multi-selects of events or crews all of the events or crews in the resulting selection will be filtered in the Events and Crews tool, when map selection filtering is enabled (see Working with the Events and Crews Tool).
