Defining Compatible Unit Contractor Bids
The CU Contractor Bids portal is used to display and maintain contractor bids.
You can access the portal from Admin, select Construction Work Management, then select CU Contractor Bid. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • CU Contractor Bid: This zone provides information, such as bid amount and currency, about the contractor bid.
  • Other Bids by Contractor: This zone displays a list of compatible units and associated contractor bids.
  • Attachments: This zone enables users to manage all types of attachments for the compatible unit contractor bid record.
  • Notes: This zone displays notes about the contractor bid.
