Defining Equipment Groups
The Equipment Group portal is used to display and maintain equipment groups.
Refer to Understanding Construction Work for more information.
You can access the portal from Admin, select Construction Work Management, then select Equipment Group.
- Equipment Group List: This zone lists all equipment group records. Broadcast a record to display the details of the selected record.
- Equipment Group: This zone provides information about the selected equipment group.
