Defining Overheads
The Overhead portal is used to display and maintain overhead details.
Refer to Understanding Construction Work for more information.
You can access the portal from Admin, select Construction Work Management, then select Overhead.
- Overhead List: This zone lists all overhead records. Broadcast a record to display the details of the selected record.
- Overhead: This zone provides percentage details for Additional Overhead not specific to any Resource Type as well as Work Designs and Construction Work Orders associated with a selected overhead, including material overhead, labor overhead, equipment overhead, and other overhead.
