Copy Service Quantity from Master Bill Segment
Calculate Final Reading Values calculation rules determine the final values for readings based on user-defined UOM/TOU/SQI.
Rule Name: Copy Service Quantity From Master Bill Segment
Base Package Calculation Rule Business Object: C1-CopySQFromMasterBillSegment
Apply Calculation Rule Algorithm Type / Algorithm: C1-CPY-MB-SQ
Rule Parameters: -
Characteristics: Defines characteristic(s) and corresponding value(s) that are to be passed to the referenced calculation group. -
Characteristic Type: Defines the characteristic type that is to be associated to the calculation rule. Note:Characteristic Types for rates must be configured to be used on a calculation rule and/or in the characteristic collection. Refer to Defining Characteristic Types for information on how to set up characteristic types.
Characteristic Value: Defines the parameter value that will be associated to the characteristic type.
