Simple Summary
Simple Summary calculation rules create a "subtotal" on the bill by summarizing bill lines produced by other calculation rules in the same calculation group.
  • Rule Name: Simple Summary
  • Base Package Calculation Rule Business Object: C1-SimpleSummary
  • Apply Calculation Rule Algorithm Type / Algorithm: C1-SIMP-SUMM
  • Rule Parameters:
    • Referenced Calculation Rules: Defines the calculation rules that should be included in the summary. Note that any calculation rules listed here must belong to the same calculation group as the Summary rule.
  • Example: This calculation rule creates a summary of TOU-based charges (based on rules within the same calculation group as this rule).
    Calculation Group: Commercial TOU Electric Charges
    Calculation Rule: KWHTOT
    Sequence: 40
    Description: Consumption Subtotal
    Description On Bill: Consumption Subtotal
    Print: Yes
    Print if Zero: No
    Rounding Type: Nearest
    Precision: 0.01
    FCPO: No
    • Off Peak - kWh
    • On Peak - kWh
    • Shoulder Peak - kWh
      Cross Reference:
    • Member Category (Category Type / Value): Taxable / State Tax
