Customer Information Zone
The Customer Information Zone is a grid that contains information about the current person and account. Pushing the button adjacent to the information transfers you to an appropriate page. The following table lists the type of information that may appear in this zone and the page to which you will be transferred if you push the adjacent button.
Rows are suppressed if the related data is blank for the person / account.
Label
What Is Displayed
Drill Down Transfers You To
Account ID
The account's unique identifier (i.e., account ID) is displayed
An account context menu has been provided (allowing you to drill to a variety of account-oriented pages)
Main Customer
The main customer's name. Note, the person's name is formatted by a plug-in algorithm on the installation record. Refer to the base package's name format algorithm (PERS-INFO) for an example. If you prefer different formatting logic, your system administrator should configure the system appropriately
A person context menu has been provided (allowing you to drill to a variety of person-oriented pages)
Set Up Date
The account's setup date
Account - Main
CIS Division
The account's CIS division
Account - Main
Customer Class
The account's customer class
Account - Main
Bill Cycle
The account's bill cycle
Account - Main
Current Credit Rating
The account's current credit rating
Account - C&C
Next Credit Review Date
The next date on which the account's debt will be reviewed by the account debt monitor. Refer to When Is An Account's Debt Monitored for more information.
Account - C&C
A separate row is displayed for each characteristic linked to the account. Each row's label is the characteristic type's description. If the characteristic is future dated, the effective date enclosed in parentheses prefixes the description.
The characteristic's value
Account - Characteristic
Auto Pay Source
The account's auto pay source
Account - Auto Pay
A separate row is displayed for each miscellaneous person linked to the account. Each row's label is the person relationship type's description.
The main name of the miscellaneous person
Budget Plan
The account's budget plan
Account - Budget
A separate row is displayed for each characteristic linked to the person. Each row's label is the characteristic type's description.
Person - Characteristic
A separate row is displayed for each telephone number linked to the person. Each row's label is the phone type's description.
The telephone number
Person - Main
A separate row is displayed for each identifier linked to the person. Each row's label is the ID type's description.
The person identifier value
Note: The system supports encryption for Person Identifier. If your implementation has configured the system to encrypt Person Identifier, the data will be displayed with a masked value; such as, *******.Refer to Encrypting Sensitive Data for more information.
Person - Main
Email Address
The person's email address
Person - Miscellaneous
Service Provider.
The service provider's name and a description of the service provider's billing relationship as of the effective date.
SA Relationship - Main
Warning:
This zone does not support User Interface Masking. If your implementation masks any of the information that appears on this zone, you must disable it and implement a zone that will mask your data appropriately. The demonstration system provides a sample zone that your implementation can import and then customize if necessary; this zone's code is CI_​CIMAP. To disable the base package zone simply deny access to its associated application service. You should only grant access to your new Customer Information zone.
