Service Points With Multiple Items
An example will help explain a single service point with multiple non-badged items. Assume you have a parking lot with 4 lights, none of which are badged.
This illustrates a premise with one service point and multiple non-badged items. One item is created for each item type and the quantity is defined for each type of item.
You can set up the above example with one premise with a single non-badged service point. On the service point, you create one item for each type of item in the parking lot:
  • 20K lumen lamp
  • 10K lumen lamp
  • pole
For each type of item, you indicate the quantity that exist in the parking lot:
  • 20K lumen lamp - 2
  • 10K lumen lamp - 2
  • pole - 4
