A Package With More Complex Operators
One of the eligibility groups described under Criteria Groups versus Eligibility Criteria has the following eligibility rules:
  • Customer must live in California
  • Service provider is A, B or C
The eligibility group in which these rules would be defined looks as follows:
Group
No.
Group Description
If Group is TRUE
If Group is FALSE
1
Lives in California, current service provider is either retailer A, B or C
Eligible
Ineligible
The following criteria will be required for this group:
Group 1: Lives in California, current service provider is either retailer A, B or C
Seq
Field to Compare
Comparison Method
If TRUE
If FALSE
If Insufficient Data
10
Algorithm: retrieve order's state
= CA
Check next condition
Group is false
Group is false
20
Misc Field On Order: Current electric supplier
IN A, B, C
Group is true
Group is false
Group is false
This example is very simple. The only thing worth pointing out is that a number of operators can be used when you define a "comparison method". Refer to Package - Eligibility for the complete list of operators.
