Oracle Utilities Smart Grid Gateway Installation Guide
Installation Overview
Application Architecture
Tier 1: Desktop/Client, or Presentation Tier
Tier 2: Web Application Server, Business Application Server, Batch Server Tier
Tier 3: Database, or Persistence Tier
Installation Components
Installation Types
Initial Installation
Demo Installation
Upgrade Installation
Recommendations for Creating a Production Environment
Media Pack Components
Documentation Packages
Installation Packages
Supported Platforms and Hardware Requirements
Software and Hardware Considerations
Operating Systems and Application Servers
Application Server Memory Requirements
Support for Software Patches and Upgrades
Planning the Installation
Before You Install
WebLogic Native Installation
Application Server Clustering
Directory Names
Prerequisite Software List
Prerequisite Software for Database Server
Prerequisite Software for Application Server
Web Browser Requirements
Installing Prerequisite Software
AIX 7.2 TL5+ Application Server
Setting Up and Using the Additional JAR Directory
Special Note to Upgrade from a WebLogic 12.1.3.x Environment
Readiness Checklist
Installing Oracle Utilities Smart Grid Gateway—Initial Installation
Before You Install
Initial Installation Procedure
Installing the Database Component
Installing Application Components
After the Installation
Operating the Application
Installing Oracle Utilities Smart Grid Gateway—Demo Installation
Before You Install
Demo Installation Procedure
Database Component Installation
Application Components Installation
Installing Oracle Utilities Smart Grid Gateway—Upgrade Installation
Before You Upgrade
Upgrade Procedure
Database Component Upgrade
Application Components Upgrade
Configuring the Oracle Utilities Smart Grid Gateway Adapters
Configuration Tasks for the MV90 Adapter
Deploying the OSB Adapter for the MV90
Starting the Application
Creating WebLogic Domain
Configuration Tasks for the Adapter Development Kit
Deploying the OSB Adapter for the Adapter Development Kit
Deploying the SOA Adapter for the Adapter Development Kit
Configuring Security for the SOA System
Configuration Tasks for the Adapter for Networked Energy Services
Deploying the OSB Adapter for Networked Energy Services
Deploying the SOA Adapter for Networked Energy Services
Deploying the Test Harness
Configuring the Networked Energy Services Head-End System to Report Events
Configuration Tasks for the Adapter for Itron OpenWay
Deploying the OSB Adapter for the Itron OpenWay
Deploying the SOA Adapter for the Itron OpenWay
Configuration Tasks for the Adapter for Landis+Gyr
Deploying the OSB Adapter for Landis+Gyr
Deploying the SOA Adapter for Landis+Gyr
Configuration Tasks for the Adapter for Sensus RNI
Deploying the OSB Adapter for Sensus RNI
Deploying the SOA Adapter for Sensus RNI
Configuration Tasks for the Adapter for Silver Spring Networks
Deploying the OSB Adapter for Silver Spring Networks
Deploying the SOA Adapter for Silver Spring Networks
Configuring SOA Authorization Policies
Creating WebLogic Server Groups
Creating Application Roles
Creating Application Policies
Creating an Example WebLogic Domain
Creating an OSB Example Domain
Creating a SOA Example Domain
Deploying OSB Adapter on SSL
Deploying SOA Composites on SSL
Deploying OSB Adapters with DataRaker
Installing Oracle Utilities Service Order Management
Demo Installation
Additional Tasks
Importing Self-Signed Certificates
Customizing Configuration Files
Integrating Existing Customer Modifications
Building Javadocs Indexes
Configuring the Environment for Batch Processing
Customizing the Logo
Other Tasks
Configure Node Manager Properties to allow SSL
Configure setDomainEnv.sh Script
Update SPLEBASE
Update setDomainEnv.sh
Database Patching
Installation Menu Functionality
Installation Menu Functionality Details
Installation and Configuration Worksheets
Application Framework Installation and Configuration Worksheets
Menu Block 1: Environment ID, Roles, Third Party Software Configuration
Menu Block 2: Keystore Options
Menu Block 50: Environment Installation Options
Menu Block 1: Environment Description
Menu Block 2: [WebLogic] Business Application Server Configuration
Menu Block 3: [WebLogic] Web Application Server Configuration
Menu Block 4 - Database Configuration
Menu Block 5 - General Configuration Options
Menu Block 7 - OUAF TrustStore Options
Menu Block 8 - OSB Configuration
Menu Block 9 - SOA Configuration
Menu Block 10 - SOA Configuration Plan (MDM)
Menu Block 11 - Configuration for DataRaker Integration
Menu Block 16 - SOA Configuration Plan (LG)
Menu Block 17 - SOA Configuration Plan (NES)
Menu Block 18 - SOA Configuration Plan (Sensus)
Menu Block 19 - SOA Configuration Plan (SSN)
Menu Block 20 - SSN JMS Source Destination Bridge Configuration
Menu Block 21 - DG Reference Implementation SOA Configuration
Menu Block 22 - SOA Configuration Plan (Itron Openway)
Advanced Menu Options
Meter Data Management Installation and Configuration Worksheets
WebLogic OSB Configuration
WebLogic SOA Configuration
WebLogic SOA Configuration Plan
Smart Grid Gateway Installation and Configuration Worksheets
For the Adapter Development Kit
For the Networked Energy Services Adapter
For the Itron OpenWay Adapter
For the Landis+Gyr Adapter
For the Sensus RNI Adapter
For the Silver Spring Networks Adapter
Common Maintenance Activities
Application Framework Prerequisite Patches
Oracle Utilities Smart Grid Gateway Release 2.5.0.1.1 Installation Guide
