About Program Subscriptions
Program subscriptions represent a customer's enrollment in a program, and link a customer with a program and (in most cases) a device location. Customers can have separate program subscriptions for different device locations and programs.
Metered service records serve as a parent to individual program subscriptions for each of a customer's programs and/or device location. Program subscriptions are most often created as a result of the customer enrollment process, but can be created on an ad-hoc basis if needed.
Program subscriptions are defined by the following:
  • Program Subscription Type: The program subscription type associated with the program. Program subscription types define certain parameters and attributes of a class of program subscriptions.
  • Metered Service: The metered service record that serves as a "parent" for the program subscription.
  • Settlement Group: A metered service for the Main Customer associated with the program subscription, used to group program subscriptions for customer settlement transactions.
  • External Account ID: An ID used to identify the program subscription in external systems.
  • Main Customer: The program subscription contact for the customer associated with the program subscription.
  • Status: The current status of the program subscription.
  • Start and End Date/Time: The date and time on which the program subscription record started, and ended (if applicable).
  • Time Zone: The time zone associated with the program subscription.
  • Device Location: The device location associated with the program subscription. This defines the devices for which the customer is enrolled in the program.
  • Program: The program in which the customer is enrolled.
  • Program Enrollment Source: The source of the customer's enrollment in the program. Options incude:
    • Bring Your Own: The enrollment was created as a result of the customer installing their own controllable device.
    • Contact Center: The enrollment was created by the customer contacting the utility's contact center. This includes enrollments created via the Customer Enrollment Process Flow.
    • Self Service: The enrollment was created via an online customer self service portal.
  • Transaction Calculation Groups: One or more effective dated program calculation groups that contain program calculation rules used to calculate scores for devices associated with the program subscription. If more than one group is defined on the program subscription, the group with the latest effective date/time is used.
  • Fallback Transaction Calculation Groups: A list of one or more effective dated program calculation groups used if a program calculation group is not defined on the program subscription (from the program subscription type).
System Data
Program subscriptions are based on the following system data:
Data Type
Description
Maintenance Object
Usage Subscription (D1-US)
Business Object(s)
Program Subscription (X1-ProgramSubscription)
