Defining Program Types
You use the Program Type portal to display and maintain a program types.
Refer to Understanding Program Types for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Program Type.
Program Type List: This zone lists all program type records. Broadcast a record to display the details of the selected record.
Program Type: This zone displays the selected program type.
