Extending Asset Statuses
If your implementation needs to create a new Asset Lifecycle BO
with a status which differs from the base package, you can choose
to create them by extending W1-AssetDisposition. With this extension,
note the following:
‘assetRelationship’ on the Asset Disposition has 3 values: Installed, Attached, and Not Installed.
- Installed is applicable to assets when they are installed in service.
 - Attached is applicable to components when they are attached to an asset.
 - Not Installed is applicable when assets or components are in other statuses (in store, in receipt, in repair, rejected, or retired).
Since the assetRelationship is in a Character Large Object (CLOB), the base package uses a naming convention using the asset disposition code. The first two characters should be ‘IN’ for installed, ‘AT’ for attached, and ‘NI’ for not installed.
