9.5.3 Create and Execute a Custom Run Pipeline for Balance Revaluation Management Ledger Process
To create and execute the custom Revaluation process using the custom Run pipeline for Balance Revaluation Management Ledger process, see the Create and Execute Revaluation Process section.
To use a standard out of the box Run pipeline for Balance Revaluation Management Ledger Process, see the Balance Revaluation Management Ledger process section in the Use Standard OFSBCE Run Pipelines section.
