Conversion Processes
The following table lists the various background processes that are executed while migrating data from an external system into ORMB. The usage of these background processes may depend upon your organization's data migration strategy:
Batch Control ID Program Name Description Multiple Threads Extra Parameters Records Between Commits / Minutes Between Cursor Re-Initiation
CNV-ADM CIPVADMB Creates ADM triggers for converted accounts. Yes
MAX-ERRORS = Used to override the maximum number of errors after which the batch must be terminated.
200/15
CNV-BAL CIPVVSAB Sets the correct balance for all contracts created during conversion. It creates adjustments that cause each contract's current and payoff balances to equal their balance in the prior system. No
SET-PYOF-ZERO= Adjustment Type to set payoff balance to zero
SET-CURR-ZERO = Adjustment Type to make current balance zero
SET-PYOF-BAL= Adjustment Type to set payoff balance to the desired balance
SET-CURR-BAL = Adjustment Type to set current balance to the desired balance and age
200/15
BASE-DATE= Base Date of Aged Debt. This should be entered in the format YYYY-MM-DD.
FILE-PATH= Path and filename of input data file
CNV-BCG CIPVCBCB This process resets the Balance Control column on all FT's so that the FT's can be included in a balance control (see the last step below) after they have been transferred to production. Yes
200/15
Please refer to Column Descriptions for more information on the columns used in the table above.
