Column Reference for Membership Type
In order to ask the customer service representative to define an appropriate service credit membership type, you must define a column reference for the membership type.
Add a new column reference with the following information:
- Column Reference: SCM-TYPE
- Description: SC Membership Type
- FK Reference: SCM TYPE
- Long Description: Service Credit membership type to use when creating a service credit membership at start time.
Column Reference Algorithms. This column reference indicates
a validation algorithm and a posting algorithm. However, we have not
defined them yet so for now simply save this information.
