Searching for a Bill Segment Level Anomaly
Procedure
To search for a bill segment level anomaly:
Click the Menu link in the Application toolbar.
A list appears.
From the Main menu, click Diagnostic Central.
The Diagnostic Central screen appears.
In the Search Anomaly zone, enter
the search criteria by selecting Bill Segment Level Anomaly option in the Search By field.
Note: ORMB search engine supports wildcard search, where you can substitute the percentage (%) symbol as a stand in for any word or letter in a search criteria. You can use the '%' wildcard character in all input fields except the date and ID fields. The '%' wildcard character is suffixed automatically at the end of the partial search criteria. Therefore, you may or may not specify the wildcard character at the end of the partial search criteria. However, you have to prefix the wildcard character manually wherever required.
Click Search.
A list of bill segment level anomalies that meet the search criteria appears in the Search Results section.
Related Topics
For more information on... | See... |
Diagnostic Central screen | Diagnostic Central |
Search Anomaly zone | Search Anomaly |
