Mounting the Workstation 820 on the Low Profile Stand
Unpack the Low Profile Stand box. Retain the box and foam for potential storage or shipping needs.
Insert the Workstation 820 into the four openings on the Low Profile Stand mounting plate until it clicks into place, and then use the Oracle 2.5mm hex key or equivalent to lock the assembly (optional).
Figure 4-12 Mounting the Workstation 820 on the Low Profile Stand
Connect the Workstation 8 Series power supply to the Power In port on the Workstation 820. Follow the cable routing path as shown below.
Workstation 8 Series ports and cables are color-coded to simplify assembly.Figure 4-13 Connecting the Workstation 8 Series power supply to the Workstation 820
Connect your country-specific power cord to the Workstation 8 Series power supply. Ensure the power cord is fully inserted into the power supply socket.
Plug the power cord into a power outlet, and then touch the power button for two seconds to power on the Workstation 820.
