Setting the Relative Capacity for Each Component
The following steps describe the optional configuration for capacity settings in the Components module.
  1. Select the Enterprise level, click Configuration, and then click Components.
  2. Select the record, and then click the General tab.
  3. In the Capacity section, set the Capacity Usage to the desired value.
  4. Click Save.
