Setting the Relative Capacity for Each Order Device in a Kitchen Theme
The following steps describe the optional configuration for your order device(s) capacity settings in a kitchen theme.
  1. Select the property, click Setup, and then click Kitchen Themes.
  2. Select the record, and then click the KDS Client tab.
  3. In the Panel Configuration section, set the Capacity to the desired value.
  4. Click Save.
